you can get a 240gb SL308 or 275gb MX300 instead of the 850 evo, cheaper PSU and case, get windows from reddit for $25.
https://linustechtips.com/topic/862632-first-build/#findComment-10725447
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($279.89 @ B&H)
CPU Cooler: Reeven - Justice 82.1 CFM Sleeve Bearing CPU Cooler  ($42.99 @ Newegg Marketplace)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($124.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($154.99 @ Newegg)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($79.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($41.77 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB OC BLACK Video Card  ($739.99 @ SuperBiiz)
Case: DIYPC - Vanguard RGB ATX Mid Tower Case  ($69.98 @ Newegg)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($88.89 @ OutletPC)
Total: $1703.47
Generated by PCPartPicker 2017-11-21 00:13 EST-0500
https://linustechtips.com/topic/862632-first-build/#findComment-10725473
You're waiting for Black Friday I hope...
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/862632-first-build/#findComment-10725477
Yes, where do you believe I should be camping out for parts? Also, you don't think I should go for the i7-8700k...why not? Sorry, not trying to question your knowledge, trying to learn where I'm doing overkill and why it is overkill.
https://linustechtips.com/topic/862632-first-build/#findComment-10725491
I didn't say you shouldn't :P
I'd take a long look at the 8600k though. If you're just gaming (you never said what your system is used for) then I'd just save the money and go that route.
Other than that:
  • Why the 1080 Founders card? I'd go with something with a custom cooler
  • I'd get an ATX motherboard in an ATX case, otherwise it looks odd
https://linustechtips.com/topic/862632-first-build/#findComment-10727516
