Its in the scenes with a lot of movement that it gets kind of fuzzy. I would try upping the bitrate to something between 5,000-10,000 Mbps, and then maybe try a different encoder. What kind of hardware are you running (besides the 1050TI)? Some encoders will be better for different hardware.
https://linustechtips.com/topic/862535-best-obs-settings/#findComment-10724748
I recently upgraded to a i7 7700 because i wanted to stream (overkill i know)8gb of ddr4 ram,1TB HDD.If i use the CBR option for bitrate,can i use 100,000 bitrate?
https://linustechtips.com/topic/862535-best-obs-settings/#findComment-10724766
I would suggest you research each of the settings so that you learn what is best to use on your system, instead of just changing things randomly without understanding what any of it does.
https://linustechtips.com/topic/862535-best-obs-settings/#findComment-10724781
If i wanna record like fast pace games (overwatch) and get pixelation,is it because of my bitrate?And if i increase it,will it make a difference since yt just export the video as a lower bitrate
https://linustechtips.com/topic/862535-best-obs-settings/#findComment-10724859
A greater bitrate does not mean greater image quality. 100,000 Mbps bitrate would destroy your storage XD.
https://linustechtips.com/topic/862535-best-obs-settings/#findComment-10724980
