would adding a side fan help GPU temps
Go to solution Solved by Vindola,
Hey,
Sorry if it seems like I am spamming, I would just like to know if adding a side fan right on the gpu help a gpu with a blower cooler.
THANKS!
A bit. The benefits of it will not be seen in performance, but temperatures might drop 2 - 3 degrees when it's running at max. On the longer run, this can give slightly extra lifetime to the GPU. However, even if you didn't place a fan, by the time the GPU dies it will probably be really outdated.
Nothing drastic, but if your case isn't particularly well ventilated then it can't hurt anything.
Blackout - Intel Core i5-4670K | Xigmatek Dark Knight II Nighthawk Ed. | Gigabyte GeForce GTX 770 (2GB) | 8GB Corsair Vengeance Mem. | Gigabyte GA-Z87X-D3H Mobo | 250GB Samsung 840 Series SSD | 1TB WD Black HDD | Seasonic Platinum SS-660XP2 660w PSU
Hey,
THANKS!
Thanks a ton for all the help :)
I see no difference when my side fan is disconnected or connected. (I have a reference blower card) I guess it really depends on the computer case if you have little airflow you will benefit but if you have a case with really airflow you will me like me and see no difference.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
