Should have
  • 2+3.5"drives
  • 2+2.5" drives
  • mounting for atleast 3 fans(120mm)
  • support for a 240mm rad(cooler master ML240)
  • atx powersupply
  • atx motherboard
would like
  • side window
  • RGB
  • black build
  • water cooling support
Here are the options I am considering
Cooler master master box 5 lite RGB
Cooler Master master box 5
Corsair 780T (used)
Corsair spec 04
Thermaltake view 21
Thermaltake versa c22 RGB
Zebronics cyclone
https://linustechtips.com/topic/862144-case-recommendation-please/
you could use like any case in the market if those are your requirements, however i have the masterbox lite 5 and i dont know about the included fans but the case itself is great. wish uit had rubber grommets though.
Im not sure what this signature thing is but it could use some RG
I second that. I don't own it, but it looks like a very feature-packed case for the price. I would also take a look at the newly released masterbox mb600l as well.
My main desktop, "Rufus":
PC Specs:
CPU: AMD Ryzen 5 1600
CPU Cooler: Cooler Master MasterLiquid Lite 120
RAM: 2x8gb Corsair Vengence DDR4 Red LED @ 3066mt/s
Motherboard: MSI B350 Gaming Pro Carbon
GPU: XFX RX 580 GTR XXX White
Storage: Mushkin ECO3 256GB SATA3 SSD + Some hitachi thing
PSU: Seasonic Focus Plus Gold 650W
Case: Corsair Crystal 460X
OS: Windows 10 x64 Pro Version 1607
Retro machine:
PC Specs:
CPU: Intel Core 2 Quad Q9550
CPU Cooler: Stock heatsink
RAM: GSkill 4gb DDR2 1066mt/s
Motherboard: Asus P5n-e SLI
GPU: 8800 GTS 640mb, I swap between that and my 8800 GTS 512mb
Storage: Seagate 320gb right from 2006
PSU: Ultra 600W
Case: Deepcool Tesseract SW
OS: Windows XP SP3 32-bit, Linux Mint 18.2 Cinnamon 64-bit, Manjaro Deepin x64 (sorta)
Mac Pro Early 2008: Dual Xeon X5482s w/ 32GB RAM & HD 5770 running macOS High Sierra
More PC's
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
1 minute ago, Vandorlot said:
NVM thats seems like its to expensive should have thought some more. View 21 in my opinion. I wouldnt evern think of getting the zebornics, the versa looks much worse irl than it does in the photos,. Id also take the masterbox.
My Rig
 Peripherals
does the  masterbox (non lite )5 has the same probs?
2 hours ago, andrewmp6 said:
$238 for shipping goodness gracious
