So i am going to make my own sleeved cables for the corsair hx750i psu and i have just noticed on corsairs website that the 24pin on motherboard side contains a pin with no terminal on it. Does this mean i will have to make a split cable or can i put a terminal down it  ( so no spit wires ) with out any danger to the motherboard?
  • CPU - Ryzen 7 1700 Motherboard - Ax370 gaming k5 RAM - 2x 4gb ddr4 3000mhz T - force vulcan
  • GPU - Gtx 1070 ti founders edition Case - Phanteks enthoo evolv atx tempered glass Storage - 120gb ssd, 1tb hdd PSU - Corsair hx750i Display - Acer xb271hu Cooling - Cryorig h5 universal Keyboard - Logitech mk270 Mouse - Logitech mk270
  • Operating System - Windows 10 home 64 bit
https://linustechtips.com/topic/861996-sleeving-cable-help-plz/
The cables are pinned that way for a reason, just don't know exactly what it is.  But, if you install a pin into that spot, do you know what the corresponding spot on the motherboard is for?  Does the motherboard have a pin in that spot?  I would be afraid to install a pin in to that spot not knowing what the corresponding spot on the motherboard is for.  You definitely don't want to put a current/voltage in a spot where it isn't wanted.  You run the risk of smoking either the mobo or some other important device.
https://linustechtips.com/topic/861996-sleeving-cable-help-plz/#findComment-10719555
Pretty sure it is a ground terminal.
https://linustechtips.com/topic/861996-sleeving-cable-help-plz/#findComment-10719625
You can put a terminal down it. It is not used on any motherboard. When I made custom cables, I just made a dummy wire that didn't connect to anything to preserve the aesthetic.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
https://linustechtips.com/topic/861996-sleeving-cable-help-plz/#findComment-10719736
Dual or double wire are almost always inevitable on most PSU's, some units have a direct 1:1 connection but that isn't always the case.
For the missing pin that was used for older systems that required a -5V which is not necessary anymore. If you want digrams and such I have a general guide and details on it here under PSU connectors and Pinouts:
Image result for 24 pin diagram
https://linustechtips.com/topic/861996-sleeving-cable-help-plz/#findComment-10719888
Most PSU cables have 23 pins Plus two to three Y cables (Which Requires soldering). You would need to check your motherboard manual to see what voltage is coming out of that missing slot.
When creating cables you should have multimeter & a PSU tester.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/861996-sleeving-cable-help-plz/#findComment-10720053
I did custom cables for this PSU in my current rig, and if I remember correctly, it had one double wire for the 24 pin, and one double for each 6+2 pcie cable (with the double being the +2). As someone else said, I used a dummy wire to fill that spot, but didn’t connect the psu side.
I was able to trace the pin out just by looking at the cables. I can post a pic of my diagrams when I get home if you’d like
CPU - 1700X 3.7gHz | CPU Cooler - EK and Singularity Custom Loop | Motherboard -  Asus X370 Crosshair VI w/ EK Monoblock | RAM - Corsair Vengeance RGB (4x8GB) 3000Mhz w/ Silver Paint| Graphics Card - Asus GTX 1080ti Strix OC w/ EK Fullcover block with custom vertical mount | Power Supply - Corsair HX750i w/ self made Custom Cables and 3D printed Combs | Storage - 3x 3TB, 2TB HDD | Samsung 960 EVO 500GB NVME SSD, 500GB OCZ SSD | Case - Lian Li PC-09 Custom paint | Colour Theme - Silver & Black & RGB lights
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Logitech MX Master 2S Mouse/Wacom Intuos Pro5 Med
https://linustechtips.com/topic/861996-sleeving-cable-help-plz/#findComment-10727907
