Only see 1 hard drive
Solved by Guest,
4 hours ago, RockiLocky said:I did check my cable and my supply of power. Even changed them.
Nothing changed. I still see the HDD in my bios, but with 500M. I still see it in device manager. and still same problem for disk management.
Any ideas?
EDIT:
It doesnt even show up in Windows anymore. Neither in disk management nor in device manager. Furtheremore it doesnt show up when I use command prompt go: list diskneither shows up there
it doesnt show up in bios anymore either
Edit 2: Got it to show up in bios under boot with the 2tb but not showing up in windows at all
Is it within the warranty period?
