Hello,
I overclocked to 5Ghz using 1.35v then I experienced 80c in game so I thought I would try and lower the temps. I went into the bios and tried Asus Multicore Enhancement. I disabled it and booted into windows and the vcore showed around 1.52v!
What the hell happened? Anyone have any idea what I did wrong? I tried to lower the temps not destroy the CPU!
Thanks a lot for any help...
https://linustechtips.com/topic/861321-8700k-mce-issue/
When you disable that the mobo most likely also revert your voltage settings. These auto-tools are dumb..
Desktop benching:
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10713824
8 minutes ago, danlinus84 said:
Hello,
are you looking at the VCORE or VID?
turn off MCE when overclocking. and set voltages manually to 1.35v. check if MCE changed the voltage settings.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10713835
4 minutes ago, danlinus84 said:
Definitely was looking at vcore in hw monitor
use quote post.
revert back to your old 5ghz settngs and disable MCE. and lower your voltages from there.
Old Rig
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10713852
5 minutes ago, WereCat said:
MCE is the Auto-OC function that heavily overcompensates on voltage most of the time... it varies from board to board.
I just don't understand. I thought it would reduce temps! I had svid behaviour set to best case scenario. For my 5ghz oc I had 1.35v llc level 6. I am wondering if that could have made the stock intel setting (mce disabled) go to 1.52v because of the llc?
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10713882
Turn off MCE, turn off CPU SVU support and ajust load-line calibration accordingly.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10713910
But having it enabled in the first place kept my voltage at 1.35v and disabled 1.52v. The overclock was completely stable I was just trying to lower load temps. There's no way I am changing it back now!
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10713919
I dont know how Asus's software works since I havent touched their overclockable mobo myself, but if your current settings only work with MCE enabled then keep it there. My idea is that you opt for 'auto' voltage right from the start when you start overclocking, which overcompensates voltage as you increase the clock speed (which is perfectly normal since mobos have to accommodate chips of the worst silicon quality). MCE is the one that limits the voltage.
Desktop benching:
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10715240
Quote
ASUS Multicore Enhancement: Setting to Auto applies the Turbo ratio to all cores. Setting to Disabled uses Intel Turbo policies. These options are only effective at stock CPU settings. When a manual overclock is applied, the Turbo ratios are assigned according to the CPU Core Ratio settings.
I read this on the kaby lake overclocking guide. I still don't understand how this applies to voltage as I already set my voltage to max 1.35v
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10715477
I used 5GHz mode from ASUS BIOS on my i5 8600k. It set voltage to 1,45V ... needless to say I disabled it and went with manual OC like I was planning from the beginning. Was just interested what settings they used for that "5GHz Try Me" profile xD
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/861321-8700k-mce-issue/#findComment-10715490
