Okay I just had very bad temp problems. I already replaced my thermal paste three times to no avail. My Computer shuts down every time it reaches 80+ Celsius when idling with a chrome bar. (Takes about 6-8 minutes to shut down)
CPU cooler is amd stock cooler (it spins at 2000+ rpm) and I just bought the components five days ago. how do I even go about fixing this?
https://linustechtips.com/topic/86128-cpu-cooler-problem/
An AMD CPU shouldn't be reaching 60C, let alone 80.
Are you sure the cooler is making proper contact with the CPU?  It seems there's no heat dissipation going on at all.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/86128-cpu-cooler-problem/#findComment-1169804
Well I pressed it quite firmly. It never happened before when I didn't install any windows update but I don't think it would contribute so much of a difference
https://linustechtips.com/topic/86128-cpu-cooler-problem/#findComment-1169822
