Build for Friend
Go to solution Solved by RadiatingLight,
Just now, TurbulentWinds said:
I'm thinking a 1050 Ti, 1060 3 GB, or a used 980 Ti for the build, however, I am not familiar with the good and bad cooler designs on the 1060 3 GB.
at least a 1060 3GB. and that one is pretty efficient, so basically anything will be fine. if you have some spare budget, try go for a dual-fan card, but any 1060 3GB will be fine.
ideally, a 1060 6GB would be best (or RX 480/580)
used 980 would be a good option
used 980Ti is great, but probably costs too much. if you can get one, go for it (note that with a 980Ti, you'll need a bigger PSU (550W+)
2 minutes ago, TurbulentWinds said:
I would like a 550-650 watt PSU for future upgrades but again I am not familiar with the PSU tiers. I do have the list but I don't want to screw up the pick.
TBH that's more than you need with such a tight budget.
450W is more than enough for what you need (unless buying a 980Ti, in which case it could probably still run the system, but would be under lots of load)
I have a link in my sig "you don't need a big PSU" that you should watch to see how little power modern components really use.
3 minutes ago, TurbulentWinds said:
I know next to nothing about monitor companies so I just want something that is 1080p, 60 hz.
then go to PC Partpicker, sort monitors by 1080p, and IPS, then choose the cheapest one.
I'm trying to make a midrange gaming PC for my friend for about $500-600 not counting the monitor.
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($125.89 @ B&H)
Motherboard: MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard  ($121.95 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($74.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($41.77 @ OutletPC)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($59.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($88.89 @ OutletPC)
Thank you all for your help!
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/861096-build-for-friend/
What's the budget?
(Ryzen 1400 would be cheaper and better than i3 8100 IMO)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10711988
Just now, RadiatingLight said:
What's the budget?
First sentence, bud!
1 minute ago, RadiatingLight said:
What's the budget?
I understand that Ryzen is cheaper and is going to perform better, however, my friend is not confident in using "fringe" hardware as he is just switching over to PC.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10711995
Fringe hardware omg.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10711998
xD I know, right!
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10711999
xD I know, right!
If your friend is so budget conscious, Ryzen should be his first choice. AMD are sticking with AM4 till 2020, so if he grabs a B350 and a Ryzen 1400, he can upgrade all he wants. Intel on the other hand only have z370s right now for Coffee Lake, and it's a massive waste buying a premium motherboard for an i3.
Going with ryzen would probably even free up enough budget for a 1060 6GB, which would absolutely crush 1080p gaming, at least for now and the next year or two.
My PC:
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712007
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($147.79 @ SuperBiiz)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($40.98 @ Newegg)
Video Card: Asus - Radeon RX 570 4GB ROG STRIX Video Card  ($229.99 @ Amazon) for freesync support.
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($19.99 @ Amazon) he shouldn't be spending so much on the case at a $600 budget.
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($24.99 @ Newegg)
Monitor: Acer - KG221Q 21.5" 1920x1080 75Hz Monitor  ($99.99 @ B&H)
Total: $680.49
Generated by PCPartPicker 2017-11-17 20:47 EST-0500
get OS from reddit for $25.
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712013
I'd reccomend this:
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($50.98 @ Newegg)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB SC GAMING Video Card  ($189.99 @ B&H)
Case: DIYPC - DIY-F2-O MicroATX Mini Tower Case  ($40.98 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Total: $586.49
Generated by PCPartPicker 2017-11-17 20:49 EST-0500
Trust me, Ryzen is not fringe hardware. it's stable, and works very well. it might've been unstable/fringe for the first month, but it's very well established.
Laptop:
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712016
+1
Laptop:
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712017
I'm working with a normal person here. He didn't know that AMD existed and he is already nervous enough without going with a company he has never heard of.
I'm still a skeptic on AMD remaining relevant or releasing good enough CPUs to make the long term support on the platform worth it.
I wouldn't say that since he is planning on upgrading to an unlocked CPU, 4-5 years down the line. I prefer to buy overclocking MOBOs since it leaves a better future upgrade path.
I agree but I need to work in the confines I have.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712018
Total: $680.49
I understand that Ryzen provides better value, but my friend will not go AMD. I need the i3 8100 loadout.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712024
2 minutes ago, RadiatingLight said:
I'd reccomend this:
Total: $586.49
I know that Ryzen is well established, however, AMD does not advertise themselves well. My friend thought HP and Dell made all computers and parts until 2 days ago. He will not go with AMD as he doesn't know the space and doesn't know the company.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712029
in 4-5 years, intel will have already switched sockets twice, with the coffee lake platform being in the same spot as haswell right now.
by contrast, AMD will have much better CPUs on their AM4 platform in 4-5 years, even though they too will switch sockets by then.
Laptop:
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712034
Just now, CUDA_Cores said:
Intel coffee lake is even more "fringe" hardware than Ryzen as Ryzen has been out much longer in comparison.
I understand that. The problem is trying to make someone who just discovered AMD two days ago, that they are better than Intel, whos ads the friend has been watching their entire life.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712035
Well, you do know the space.
I'm sure he's never heard of NZXT before, or G.skill, or EVGA, etc. but since you're helping him pick, you're the expert. AMD is a great company which makes solid products. the fact that he's never heard of them doesn't mean that they're bad in any way.
Laptop:
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712038
Whatever you say, I don't want to get in a argument right now. I just need to know the below three:
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712039
Again, not the point. He will not go with AMD no matter what I say. I just need a i3 8100 system.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712042
When I built my first PC, I went with AMD. At the time, I had never heard of AMD but the price/performance was better in benchmarks. Since I have no brand loyalty, I went with AMD
Just show your friend benchmarks and they will use AMD.
They will not. I have. This is a pointless argument. I just need an i3 8100 loadout here.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712044
1 minute ago, CUDA_Cores said:
Then don't help him build a computer. If he's gonna be a fanboy, you're on your own.
At least this is what I tell my friends who are fanboys. then they come crawling back to me.
Whatever, I'll just ask separately for the parts.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712056
Laptop:
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712057
Sucks. He'll be getting a much worse PC becuase of it.
maybe tell him to wait until B360 or H310 motherboards are availible (early 2018 i think), since those will save you lots of money
if he wants one now, then he will suffer a significant hit in framerate and overall performance by going with a Z370 motherboard. (or in the case of this build, I just went over budget)
but this would be the build that I would begrudgingly reccomend for such an unfortunate scenario
Motherboard: Gigabyte - Z370 HD3 (rev. 1.0) ATX LGA1151 Motherboard  ($111.49 @ SuperBiiz)
Case: Azza - SIRIUS ATX Mid Tower Case  ($33.98 @ Newegg)
Total: $618.10
Generated by PCPartPicker 2017-11-17 21:04 EST-0500
Laptop:
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712072
As long as you wait for Black Friday, you'll be getting a good deal regardless of what you get. $99 for a Z series motherboard isn't that much more than a B or H series with a nicer feature set.
To be fair, he could just as easily upgrade to an 8700k, which should be more than sufficient at that time.
If it's not, and AMD has made some seriously amazing stuff, he can simply sell and upgrade. It's not like we're talking about real estate here, it's a few hundred dollars.
Go with the used card for sure. 980, 980Ti. Go with whatever's cheaper if he is playing on a 1080p60 monitor.
You can probably find some good deals on video cards right after Black Friday, so I'd start checking the Reddit Hardware Swap frequently.
PSU, the CXM 550w is probably your best bet. It goes on sale frequently, and for a really low price. IMO one of, if not the best extremely budget (when on sale) unit.
I like Dell for monitors.
Or just build them an AMD system and say it's intel. It's their first time building a PC so they'll never know the difference.
Not really, the 1500x gets beat by the 8100. Stock I think, but still, that's what benchmarks show.
Some people do have brand loyalty, and this forum needs to realize that, recognize that, and come to terms that it's no ta problem. Different people like different things.
That's incredibly petty, and if you do that you're a horrible friend.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/861096-build-for-friend/#findComment-10712165
