Hi, I got a motherboard P8Z77-m and i just found out that it supports RAID with INTEL rapid storage technology, and i wanted to know if it is a good solution, ATM i got a 3 tb HDD and a brand new samsung 850 EVO 250GB, I use my computer for programming purposes and some light Gaming, what would be my best option to get great performance and for storage integrity? should i buy another HDD or SSD?
Is it difficult to set up? i have no problem into clean installing windows, i need to do that anyways.
Thanks,
https://linustechtips.com/topic/860454-help-with-raid/
Thanks,
I'd get a few HDD's that are reliable and RAID the hell out of them
RAID 1 + 0 is good if you have 4 HDD's or more.
https://linustechtips.com/topic/860454-help-with-raid/#findComment-10705628
Thanks,
even then raid 1 + 0 is good with SSD's. depends on your budget.
https://linustechtips.com/topic/860454-help-with-raid/#findComment-10705631
RAID won't do much for you. RAID is not a back-up. You're better off keeping a back-up schedule using an external disk. You won't have any benefit from doing RAID with your workload.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/860454-help-with-raid/#findComment-10721870
