Intel Turbo Boost doesn't seem to be working or, at least, I don't have a way of confirming that it's working. I tried monitoring core clock speed with both CPU-Z and Intel Turbo Boost Monitor, while running Prime95 one-core benchmarks and gaming. It never exceeds 2.8 GHz (i5-8400).
Troubleshooting steps I've tried:
-confirmed that I have the latest BIOS version and Turbo Boost is Enabled in BIOS
-confirmed that Windows is in High Performance power mode
-ran Intel Processor Diagnostic Tool, all tests were passed, detected 2.7 CPU frequency
-installed Intel Extreme Tuning Utility. Confirmed that it shows Turbo Boost as "enabled". Ran a benchmark and it still shows MAX frequency at 2.75GHz
My question is: is there any way to confirm that Turbo Boost is working? All benchmarks and monitoring tools show 2.7 GHz clock speed at all times under heavy load (yes, including 1-core tests). I'm starting to believe that Turbo Boost is not working. In that case, is there any way to troubleshoot it?
https://pcpartpicker.com/b/FPKBD3  (i5-8400, ASRock z370m-ITX, GTX 1080, 16GB DDR4-3000, Corsair SF450W, Win 10 Home)
https://linustechtips.com/topic/860453-turbo-boost-not-working/
I'm pretty sure a CPU/GPU only turbo boosts if it's under a hard enough load that it actually has to speed up.
EDIT: Also make sure it's enabled in msconfig
https://linustechtips.com/topic/860453-turbo-boost-not-working/#findComment-10705528
Not sure if 450w psu is a good choice for something like that.
Desktop benching:
https://linustechtips.com/topic/860453-turbo-boost-not-working/#findComment-10705551
I don't have anything related to TB in msconfig
https://linustechtips.com/topic/860453-turbo-boost-not-working/#findComment-10708520
I believe the turbo boost for the 8600 is for one core. also check to see if intel speed step is enabled in the BIOS
i7-7700k @4.8GHz
Asus Maxmius IX hero
EVGA GTX 1080Ti FTW 3
850w EVGA PSU
32GB corsair LPX ddr4 ram
https://linustechtips.com/topic/860453-turbo-boost-not-working/#findComment-10708841
