Help Me Build A Pc
2 hours ago, Zack1990 said:well evidently it was just 1 ram stick that was stopping my system from running the power supply that was in the system still does work but not going to push it and stay with the new one so i will just have to order me some new ram so i can have me my 2 sets.
2 things, the first is the DIMM slot might be damaged, and second the second stick of RAM could be damaged too, I'm assuming you have a board with 3 4GB sticks.
I'd check all RAM to be safe, not sure if you cycled your sticks or not if not i would esp into the one that had the dead ram.
If you have a old linux disc around it will have a program called memtest86+ (should work with DDR3) if not https://www.memtest86.com/ It will display any errors, tho it could take a few hours, so sit back and read a book ![]()
