HI
so today i installed voicemeeter banana to check if i could improve my mic sound ,but i disliked it so i unistalled the software and since then im having massive issues with cpu load ...
im having huge fps drops on game like 100 fps normally and 50fps after changing the sound volume "with a keyboard scroll key"
i already reinstalled realtek sound and even the gpu driver to a older one  cause i updated it today too..
still with the same problem.
any one having the same problem or have a solutio.....waiting for a answer .
thanks
specs - gtx 1070 evga ftw
            i5-6600k oc 4.4
https://linustechtips.com/topic/860185-cpu-high-load-when-changing-sound-volume/
Clean install windows?
Sometimes programs don't uninstall correct and there's nothing you can do to get rid of the corrupted crap.
