Hi there I’m buying a Silverstone - Strider Plus 850w 80+ silver modular psu and was looking at buying some white cable mod cables and was wondering exactly what type would work for it as I noticed there are a few different ones and LTT said that he had to use the corsair psu for type c but failed to explain why
https://linustechtips.com/topic/859558-cable-mod-cables/
Look at this list to see which series you don't if you don't want to use the configurator. https://cablemod.com/compatibility/
(Configurator: https://store.cablemod.com/configurator/)
(I think you need ST-series)
PC Specs:
CPU: Intel Core i7-8700k @ 4.7GHz Turbo
Motherboard: Maximus X Hero (Wi-Fi AC) LGA1551 (300 Series)
RAM: 2x8GB Trident Z RGB DDR4-3200MHz
GPU: Gigabyte G1 Gaming GTX 1080
SDD: Samsung 850 EVO 500GB
HDD:  Seagate Barracuda 2TB
PSU: Corsair RM650x
Cooling: Corsair H115i Pro RGB
OS: Windows 10 Pro (Un-Activated Currently)
Main Display: Dell S2417DG 1440p 144/165Hz G-Sync (2560x1440)
Secondary Displays: 2 x Dell P2312H 1080p 60Hz (1920x1080)
Keyboard: Corsair K95 RGB Platinum
Mouse: Logitech G703 Lightspeed Wireless Gaming Mouse
Headset: Massdrop x Sennheiser PC37X Headset
https://linustechtips.com/topic/859558-cable-mod-cables/#findComment-10695741
PART #
ST85F-P
(or) SST-ST85F-P
Make sure to pick the F-P and not the F-G for best compatibility.
https://linustechtips.com/topic/859558-cable-mod-cables/#findComment-10695814
