Ok, I want to build a PC submerged in mineral oil. I know linus already did one, but puget has stopped selling their case kit. I want to know what a good selection of parts would be for this, and how I would go about constructing a tank.
Specs I’d like:
GTX 1060 6gb
ryzen 5 1600x
16gb DDR4
thx
Main Laptop: Google Pixelbook
Dev mode w/ Cross Enabled
PC: Ryzen 7
1700x / 32GB 2667 / GTX 1080 / 1.5 TB of SSDs / 1TB of HDDs
Monitor: AW3418DW Ultrawide
120hz / 3440x1440 / RGB / Amazonbasics Dual Monitor Arm
2nd Monitor: Dell U2515hx
25 inches / 1440p / Portrait / Amazonbasics Dual Monitor Arm
https://linustechtips.com/topic/859463-oil-pc-planning/
Are you sure?
It's basically like throwing your parts away since you can't reuse them or resell them, and it's extremely difficult to upgrade to troubleshoot anything.
https://linustechtips.com/topic/859463-oil-pc-planning/#findComment-10694866
If you really want to do it for fun then I wont stop you, but I think your pc wont benefit from mineral oil. a 1600x and a 1060 are both very efficient and cool parts and wont benefit from mineral oil at all and since your right and In general for most users it isnt worth the hassle, especially since puget inst making anymore tanks and you would have to diy one. Plus with the money you would spend on mineral oil and construction the case you could get better pc parts like a r7 or a 1070.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/859463-oil-pc-planning/#findComment-10694870
Would also like to add that its very hard to do maintenance and as you might have saw, linus case cracked and it was very hard to fix.
My Rig
 Peripherals
https://linustechtips.com/topic/859463-oil-pc-planning/#findComment-10694876
