need help with multidimensional array in a class member C++
Pachuca
I'm trying to return a multidimensional array in a member class. It should be reading from my data file which contains 3 columns of 12 rows filled with double data type like -12.2 or 3 and so on.
double lineType::readData(){
    double arrayA[12], arrayB[12], arrayC[12], retArray[12][3];
    int i = 0;
    ifstream inFile;
    inFile.open("data.txt");
    if(inFile.fail()){
        cout << "inFile failed to open.\n";
    while(!inFile.eof()) {
        inFile >> arrayA[i];
        inFile >> arrayB[i];
        inFile >> arrayC[i];
        retArray[12][3] = {{arrayA[i]},{arrayB[i]},{arrayC[i]}};
        i++;
    return retArray[12][3];
I'm getting this error when trying to complie:
error: cannot convert ‘<brace-enclosed initializer list>’ to ‘double’ in assignment
Is this a syntax issue? I'm trying to return the multidimensional array so I can use the numbers from the data file to run math calculations by using other member classes. I was planning to return the multidimensional array than store it as a private value in the class itself.
Make an initialization of the class method  as an object to the class.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
ty
1 minute ago, Pachuca said:
ty
Can't tell if srs or not.
I'm just being a standard coder and replying with random phrases containing "class", "object" and "method". It's what every coder does when others ask for  help - reply with nonsensical shit.
Main Rig
CPU: Ryzen 2700X
being serious, I'm thinking it might work if i initialize the member function. If not, I could try changing this member class to only open/read the data.txt file than call it in another member class to store the data. Might be easier that way too.
this is what I tried... doesn't seem to fix anything though. I'm still getting the same error.
lineType::lineType(){
    lineFromDataA[12];
    lineFromDataB[12];
    lineFromDataC[12];
    double retArray[12][3];
    int i = 0;
    ifstream inFile;
    if(inFile.fail()){
        inFile >> lineFromDataA[i];
        inFile >> lineFromDataB[i];
        inFile >> lineFromDataC[i];
        retArray[12][3] = {{lineFromDataA[i]},{lineFromDataB[i]},{lineFromDataC[i]}};
        i++;
I don't know much C++, but
means one of two things:
A)Wherever your converting or setting the parameters to double is in code that's never triggered. Check the code is called, use testing methods or basic output to determine if any code in a control statement is being ran, etc.
B) The code where the parameters are changed/initialized again isn't triggered. See above.
I know that's a basic solution, if not, I'd try creating this on a smaller scale to see if your methodology is correct ,for example try it with a single array instead. You could also try using a list?
I don't know C++ so I can't directly help you, but seeing as nobody replied that's what I'd do if it was my code.
Main Rig
CPU: Ryzen 2700X
The problem is that you're trying to assign the array
to a single element of the array (specifically [12][3], which is also out of the bounds of the array). If you get rid of the [12][3] and just assign it to retArray, it still won't work though, because you're now just trying to assign an array with dimensions [3][1] to an array of dimensions [12][3] (and I also don't think you can use array literals like that in C++ though I might be wrong on that).
I don't quite understand why you have arrayA, arrayB and arrayC - they are just used for temporary storage. If they aren't used for anything else, you can make the code much simpler by replacing the body of your loop with
        inFile >> retArray[i][0];
        inFile >> retArray[i][1];
        inFile >> retArray[i][2];
        i++;
I'm not 100% sure that this will read the columns correctly though - I haven't used ifstream for a long time.
Make sure that your file isn't more than 12 lines long, otherwise your code won't work (because it will go out of the bounds of the array).
HTTP/2 203
        i++;
I'm not 100% sure that this will read the columns correctly though - I haven#t used ifstream for a long time.
This works for me, thank you. This is actually better than what I was trying to do.
edit: i was trying to store these values so I can have the class return one array to use in another member class.
To me it makes no sense to have a method read a file for data in this case. A separate function should be just fine and is more general.
Here's something I might write:
#include <iostream>
#include <stdexcept>
#include <fstream>
#include <vector>
using namespace std;
struct Row {
	double x;
	double y;
	double z;
vector<Row> read_data(const string &path) {
	vector<Row> rows;
	ifstream in(path, ios_base::in);
	if(!in.is_open()) {
		throw runtime_error("Could not open");
	while(!in.eof()) {
		Row row;
		in >> row.x;
		in >> row.y;
		in >> row.z;
		rows.push_back(row);
	return rows;
int main()
	try {
		auto data = read_data("data.txt");
		for(auto& row : data)
			cout << row.x << ", "
			     << row.y << ", "
			     << row.z << "\n";
	catch(runtime_error &e)
		cout << e.what() << "\n";
	return 0;
