Sup guys. I got 4x EK Vardar 120mm fans today for my 2x 240mm rads for my new setup. Heard they were pretty good and although temps are really nice I don't really like their noise profile. Past 1000 rpm they hum and are too loud for my taste. I don't think there's anything wrong with them- that's just a characteristic of the specific fan. The store said I could bring them back and swap them out for another fan so I've been having a look online. For my silence is almost as important as cooling performance so am naturally inclined towards something like the NF-F12. I would realllllyy  appreciate some suggestions. I know noise can be suggestive but I think my experience with the Vardar's might be a good reference point.
Thanks! :)
https://linustechtips.com/topic/858254-best-radiator-fan/
Noctua is the best choice but most people don't go for them as they are expensive. If you don't mind paying extra, go for the NF-F12
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/858254-best-radiator-fan/#findComment-10682713
I've heard that the Silent Wings 3 fans are also super quiet. Do you have any exp with them?
https://linustechtips.com/topic/858254-best-radiator-fan/#findComment-10682716
No, sorry. I would wait for more people to give input as I am not 100% sure
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/858254-best-radiator-fan/#findComment-10682726
NF-F12 is not that good acoustically.
(it's the fan on the NH-U12S; spikier and concentrated in certain frequency bands is worse than broadband)
See here:
http://www.silentpcreview.com/article1343-page5.html
iPPC version (just listen to the values with rpm 1500 and below)
To be honest, most fans that are better on radiators frequently don't have the best noise profile at higher speeds.
Do you have relatively thick and dense radiators or not? Actually, the lower-restriction rads might work better without some high pressure optimized fans (for performance at a given acoustic annoyance level). Actually on a medium restriction, a lot of times the Corsair AF are better than the Corsair SP series, for example.
I don't think there are really huge gains to be had switching from the Vardars, which are pretty decent. You just have to live with the noise character or run them at the lower rpm.
In free air the Corsair ML120 are pretty good in that regard as here:
But on a rad it won't be quite the same.
https://linustechtips.com/topic/858254-best-radiator-fan/#findComment-10684167
What rads are you using?
https://linustechtips.com/topic/858254-best-radiator-fan/#findComment-10695629
