java code help pls
Go to solution Solved by Strayuru,
Change:
String first = lukija.nextLine();
to
int first = lukija.nextInt();
and
if(first.equals(second)) {
to
if(first == second) {
And then try again, I haven't tested it.
public class Guessinggame {
     * @param args the command line arguments
    public static void main(String[] args)
    { Random rand = new Random();
    Scanner lukija = new Scanner(System.in);
        int second  = 1;
        System.out.println("Guess the number 1 - 100");
            System.out.println("Correc ");
        else{
         System.out.println("Wrong ");
        System.out.println(second);
its not work
https://linustechtips.com/topic/857314-java-code-help-pls/
Change:
to
and
to
Bespoke Software Engineer
Laptop: MacBook Air (13-inch, Early 2015) - 8GB RAM - Intel Core i5 1.6GHz - Intel HD Graphics 6000 1536 MB
DesktopGAMEMAX Onyx - AMD FX6300 Black Edition 6 Core (Overclocked to 4.1GHz) - GIGABYTE NVIDIA GTX 1050Ti Overclocked - MSI NVIDIA GTX 750Ti Gaming 1085MHz - HyperX Savage 8 GB 1866 MHz DDR3 - MSI 970 Gaming - Corsair CP-9020015-UK - Kingston SSDNow UV400 120 GB Solid State Drive
https://linustechtips.com/topic/857314-java-code-help-pls/#findComment-10673644
np joe
https://linustechtips.com/topic/857314-java-code-help-pls/#findComment-10673651
