So I have been using an Intel core i5 5200u with intel with Intel 5500 iGPU for about 3 years now for doing things with Blender and recently Unreal Engine 4. The hardrive is dying now and I need a new PC. I am 14 years old and I am extremely busy with school that I cannot afford a high end system that I would like so I did a lot of planning and decided this system probably will be the best for me. https://pcpartpicker.com/list/mKfXjc I don't want to spend much more than $550 on this PC. I plan on upgrading the memory, cpu, storage (adding an SSD), and GPU in the future but for now I am sticking to the essentials. I know it isn't going to be the best content creator friendly experience especially with a quad-core but honestly Blender has run smooth on a $400 laptop for 3 years so I am not overly concerned. I would love to hear your feedback on it! Thank you!
https://linustechtips.com/topic/857198-entry-level-budget-content-creation-build/
for blender and your production i'd actually suggest sacrificing the 1050TI for a 1050 so that you can get a 1600. but otherwise i think you balanced the build very well.
you can take a 430W~500W PSU you're still very very far from maxing that
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
4 minutes ago, Encrypt said:
If you are on such a budget, I would recommend going within the used market. You could build a decent Haswell System for the money you want to spend.
unless you can find a cheap x99 or x79 board and cpu ryzen would do better.
another option would be a dual lga 1366 board and get 2 12 cores for 24 threads.
Edited by GDRRiley
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
22 minutes ago, GDRRiley said:
why not get a dual 6 core on lga 1366. it  should even beat a 7 in muti threading.
Even though, the current price of PC components new are just too much. Most of those CPU's what are on the LGA 1366 platform are just old. I think we can both agree that he should go with the Ryzen platform, as it provides lots of highly clocked cores and great performance.
I would consider the System I specified and the things I said, if the guy wasn't going to be upgrading within the next couple of years or so. I would highly recommend the guy to pick Ryzen if he can afford it.
