19 hours ago, Donut417 said:
Does your friend see his Network in the WiFi list?
11 hours ago, Levisallanon said:
Could it be he has a 5GHz network while his NIC only supports 2.4GHz, or maybe has a certain network protocol or encryption type which isn't supported by his NIC?
Without more info about both the laptop/nic the type of wifi and the symptomps we can't help you.
Thanks guys, but I solved the problem. :)
https://linustechtips.com/topic/857012-help/#findComment-10673997
