Help with CPU upgrade
Solved by Guest,
31 minutes ago, KhakiHat said:Thus in this case, Intel would be the best option for the OP.
Basically yes. If the OP deided to upgrade to ryzen, a whole new platform brings the cost of a new mobo+CPU.
12 minutes ago, iamjsed said:I just watched Linus' review of the 8700K and I noticed that the 7500 doesn't lag too far behind the 7700K in gaming. Assuming that the 7700 is maybe a little bit closer to the 7700K in terms of general gaming performance which is my primary use case for my rig I think 7700 will be the most sensible upgrade for me.
I mean, if you want to stay on your current platform, then the 7700 is probably your most viable upgrade option.
