MSI GS40 swollen battery removal
Solved by IronSoldier,
It has one plug and is stuck down. So you'll need a non sharp but thin lever to slide under the battery and break the glue.
Featured Topics
CloseTheDoor ·
pchelp ·
pontikos ·
Posted in Troubleshooting2 -
3
wolfgangam ·
Posted in Windows3 -
9
3
