Fan Placement In Meshify C?
Orangeator
Okay so I just got my Meshify C case yesterday and just finished building it. Tomorrow my 3, 140mm fans will arrive. And I have the two including case fans that came with the case, 120mm. How should I setup the fans?
Btw, these are the fans I bought: https://www.amazon.com/Thermaltake-Pressure-Circular-Radiator-CL-F043-PL14SW-B/dp/B017AUFGHE (except I got them on sale for $37.25)
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
Since oyu cant put 3 140mm fans in the front of the case, I'd put two new fans in the front, and then I dont know, maybe one included case fan in the rear exhaust and one new fan twoards the back as exhaust and not use the last included fan? This would insure you dont have too much negative pressure in the case
