What cooler for i7 7700k?
Ancessca
So Question what cooler should I use? A Noctua NH-D15 or a Corsair H100i V2? What are temps for each?
NH-D15 for contrast, because it is easier to keep it clean than radiator
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
I assume you already have the chip?
Pay to delid it, then air cooling if you can fit it.
Or NHD15S For pcie clearance.
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
I'd say the Noctua NHD-15, $22 cheaper then the corsair AIO, generally quiter (the corsair fans tend to be a little louder when under full load), delidding is also another option to consider for noticable lower temps on air cooling, no maintanence required (anything can happen with an AIO, pump failure, blockages, leaks, etc).
Get it delidded. Then you can run nice and quiet. For aesthetic reasons and general ease of build, I prefer aio. But I'd go with the h115i for the 7700k especially if you do not delid.
im gonna delid
the maintenance and failures are uncommon?
I just got a 212 Evo for mine.  Okay, it won't look as beautiful as a water cooler, but I want some money left after I put it all together.
After you delid, almost any cooler should be more than fine in my opinion.
I got the H80i V2 for my 7700K oc'd to 5GHz and the max temp I reach while under load is 70C.
BTW my brother has the NH-D15 and it is incredible.
that cooler is not good for overclocking an i7 7700k I'm not stupid
do you know the temps for the nh-d15?
I actually do but not for an oc'd 7700K since my brother has gotten a bad CPU in terms of overclocking.
You can search for results in Google I guess. This cooler has a lot of comparisons to other very successful AIO's.
Of course, if eventually, you do go for an air-cooler, especially the NH-D15, make sure that you have a nice(+) airflow in your case.
I don't think delid is worth it on expensive cpu like that dude but that's just me.  The performance you get out of that is already balls to the wall fast.
