RCA TV wall mounts?
Izumo
Hello. I've owned this RCA LED24C45RQ for about a year and a half and I want to get a Wall Mount for it, but its VESA dimensions are 100mm x 75mm. I've searched through Amazon, ebay, newegg, etc... and can only find 75x75 or 100x100 mounts, like this one.
Should I buy one of these mounts and an adapter that will allow me to mount the TV to the wall plate? Adapter
Or should I just save up and buy a proper PC monitor that uses the 100 or 75 standard?
As of right now, I don't really need a new Display. This TV is 1080p 60Hz and that is what I run all my games at; barely get any tearing.
I would stick with the adapters for now.
@Izumo What would your monitor budget be if you were to buy new?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Immediately, nothing really. It would be a future purchase, probably in the next 3-5 months, so that I actually have time to plan and save accordingly. But it is possible to go for the 200-500 USD price range if all is well.
I would save the wall mount and monitor for later, if you can wait. If not, go for the wall mount that you want and use the top two VESA bolts for mounting.
