Hello, I am interested in water cooling my system.
My System Specs:
i5 4690k 3050GHz
GeForce GTX 750 Ti
16GB of RAM
I want to water cool my GPU and CPU, it may not seem necessary to water cool but when I play games like GTA V it gets very warm in my room, I want to cool it down so I think maybe watercooling might help. If I could please get advice on what I should do that would be great. :)
https://linustechtips.com/topic/853633-water-cooled-system/
Uhm, watercooling will make you room heat up even faster as it will transfer the heat from your case more efficiently.
Instead of spending money on water cooling you might want to upgrade your hardware
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/853633-water-cooled-system/#findComment-10632913
2 minutes ago, LemonMan512 said:
Oh? Then what could I possibly do to reduce the heat in my room coming off my PC
Your best option is to promote better airflow through the room itself or not overclock the system but that will help a marginal amount by comparison.
https://linustechtips.com/topic/853633-water-cooled-system/#findComment-10632920
as was said water cooling will just make your room heat up faster as more heat will be dissipated than is right now.
can you move your computer to a bigger room maybe? if thats the issue. or open a window, add fans to the room blowing air out and have a window so air can flow better
If you want to argue with me, and you probably will please PM me, no need to ruin threads becase you dont like how I am.
Ask me how I made 100k selling illegal narcotics!
and you think im joking, Did a lot of wrong to get my money right.
I look up to Larry Hoover.
Your homies loyal 'til the one time you tell 'em no
https://linustechtips.com/topic/853633-water-cooled-system/#findComment-10632975
My System Specs:
i5 4690k 3050GHz
GeForce GTX 750 Ti
16GB of RAM
your room won't but cooled down by doing this.
also i would spend that money on a better GPU first.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/853633-water-cooled-system/#findComment-10635135
