I recently bought a new flash drive that's a USB 3.0 and USB C duo 32gb Kingston drive. This drive today registered as two different drives with different storage sizes. Now the drive registers as a 8gb drive. This is the second drive that has had this problem and I'm leaning towards this is some user issue. Does formatting hurt them in anyway? This drive had partitions on it, but I deleted them. What are some things you SHOULDNT do with a flash drive??
After this bad experience with flash drives I'm considering using a HDD for everything. I'm getting tired of buying new drives all the time... This drive also gets warm from just being plugged in...
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/853520-flash-drive-issues/
Not sure why you would have different partitions on a flash drive. I wouldn't install an OS on a flash drive for daily use. The only reason why I have a bootable OS installed on a flash drive is for troubleshooting.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10631835
Can't really think of anything that you can't do with a flash drive other than try to save a file to it that is larger than the drive capacity.  Obviously if the drive is only 8 gigs you won't be able to save a 12 gig file.  Just asking, where did you get the drive?  Did you pick it up from Target, Walmart or off the internet and if you did get it off the internet, where?
I would try to resurrect the drive by deleting all partitions, repartition the drive, then formatting.  I have read many stories posted by people that bought a flash drive advertised as 32 gigs to only find out after purchase the drive was only 4 gigs or 8 gigs so they got scammed.  Hope that is not your case.
Also, in the process of repartitioning, make sure there are no hidden partitions.  So called hidden partitions can contain such things as malware or virus and we all know you don't want that.  By repartitioning the drive before using, you guarantee yourself that it does not/did not contain anything bad.
The software that I use for such partition and reformat stuff is called AOMEI Partition Assistant and you can get it free from their website.  I have been using them for a pretty good while now and have never had any problems.
https://www.disk-partition.com/free-partition-manager.html
Good luck.
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10631840
I had it on drives to install it on a hard drive.
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10631842
Good luck.
Amazon and I'll be returning it probably. This had Tails on it, then tor and other programs. The thing is, the drive before came up as an E: drive and a F: drive which never happened to any other drive. F: is now gone
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10631856
Which drive letter it uses is really not important.  What is important is that it has the amount of space advertised.  If you got a good deal on it, fine.  For me, I would probably hang on to it after using the AOMEI software to delete the partitions and stuff and reformatting it to make sure it was good to go.
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10631876
I paid only $20 for it, I'll try that software and if it works I'll keep it I guess
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10631923
It's coming up as two drive letters because there are two partitions on it. Run the clean command in diskpart and repartition it. It'll be the proper capacity.
  • CPU
    Intel Core i7-7820X @ 4.2GHz
  • Motherboard
    Asus Prime X299 Deluxe
  • RAM
    32GB G.Skill TridentZ RGB DDR4
  • GPU
    GTX 1080Ti FE
  • Case
    Phanteks Enthoo Evolv ATX
  • Storage
    500GB 960 Pro SSD, 240GB PNY SATA SSD, 3TB WD Red NAS
  • PSU
    Corsair RMx Series, RM850x
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
    Razer BlackWidow Chroma "Clicky"
  • Mouse
    Razer Super Mega Black Mamba of Death 9000DPI
  • Sound
    Logitech Something with a broken bass adjustment knob so it's always rupturing spleens
  • Operating System
    NSA-Approved version of Windows 10 Pro
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10631927
As far as I know, Windows can only see the first partition on the drive.  Or the first primary partition if the first one's a logical partition.
To show 2 partitions, Windows would need to be tricked into thinking that the stick is a HDD
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632019
It doesn't work... And it shows only one partition on the drive. I reformat in Ubuntu, doesn't work, Fedora doesn't work windows doesn't work... AOMEI doesn't work...
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632023
The (Edit: 2nd latest) latest Windows 10 Creators Update has support for multiple USB partitions.
If you only see one 8GB partition on the drive in Windows Disk Management, then it must be that capacity.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632028
Just now, BWLServers said:
The latest Windows 10 Creators Update has support for multiple USB partitions.
Well now windows itself doesn't recognize it and Ubuntu just doesn't like it.
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632030
Meaning you don't see the drive in disk management? Or it doesn't show up in Explorer? Or it asks you to format the drive?
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632036
AOMEI sees it but it doesn't format it or anything. And it doesn't show up in explorer or even acknowledge it's plugged in.
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632041
I'm not familiar with 3rd party tools nor do I trust them.
Using Windows Disk Management (diskmgmt.msc), does the USB drive appear?
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632045
Forgot to quote you.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/853520-flash-drive-issues/#findComment-10632046
