Old computer case with no airflow
Hello I am planning to build a pc using second hand parts.
I have a case that I want to use but it doesn't have much airflow(if any at all?).
It's an older case originally from a packard bell computer. I beleive it's µATX and I really want to use it.
My question is, will i be able to use this case and build a system without fans?
This are the specs that I will probably get:
i5
8gb ram
120gb ssd
1tb hdd
500w psu
and for the gpu i was thinking something like a gtx 760.
Do you guys think the case will be sufficient?
Here's a pic i found online: 48a0bc1637a6bd27d2000e3f9.jpg
https://linustechtips.com/topic/853206-old-computer-case-with-no-airflow/
