GTX 770M utilization issues
Alright so I solved my issue, and I'm a dunce for not figuring it out earlier. So if anyone should have this issue in the future they hopefully stumble on this thread and maybe it'll help.
The key is BD PROCHOT. Apparently I was so focused on the GPU side of things I didn't think to check the combination of the CPU and GPU together and my CPU was erroneously throttling itself because it saw the system getting too hot, even with the fans full bore. It's not. 71C is perfectly acceptable and damn cool for this model of laptop. Disabling BD PROCHOT in Throttlestop; something I didn't think to do before, immediately solved the issue completely. I can now achieve 40-50 FPS in Destiny 2 and Mass Effect Andromeda, which both hopped between 12 and 30 before. And no, I did not see any temperature spikes everything is running the same as before.
I'm going to dig through my modded BIOS and see if I can kill the command without having to use third party software.
So TLDR; don't be a dunce like me, look at the whole picture and the answer will throw itself at you. Throttlestop and disable BD PROCHOT.
