Hi all, quick question, any idea of the noise difference between a case with a tempered glass side panel and a standard side panel?
As for the pros, personally I’m not interested in a brightly lit rgb rig but cases with glass panels look very cool nonetheless.
Just don’t want to trade sound quality for looks.
cheers
Love not hate
https://linustechtips.com/topic/851843-glass-panel-proscons/
cheers
All in all sound shouldn't be affected. Glass side panels do get dirty and scratched very, very easily. I hardly even touch mine ever and it has scratches everywhere.( Fingerprints are easy enough to clean though) Side panels do make a setup look very nice, especially if you have some led lights. Over all I would recommend a side panel, it makes PCs look amazing.
https://linustechtips.com/topic/851843-glass-panel-proscons/#findComment-10615048
PROS:
+Your sense of style can be visible
+Classy (assuming no ketchup and mustard cables
+Easy view to see if a component failed
CONS:
-Prepare to have a microfiber cloth handy for wiping
-If it falls, dangerous mess of glass
-Dust under the panel will trigger OCD
https://linustechtips.com/topic/851843-glass-panel-proscons/#findComment-10615093
5 minutes ago, jeremymwilson said:
Mmm, dust is already an issue with my pc, along with cat hair...
Does your current case have good dust filters?
https://linustechtips.com/topic/851843-glass-panel-proscons/#findComment-10615150
18 hours ago, jeremymwilson said:
Yeah I guess so. Fractal design define s.
Those have good dust filters. I'f you're still having issues with dust internally, not much you can do. Externally, you might just have to clean it with soapy water once very so often (maybe twice a month, i clean my filters once every other month and wouldn't consider my house dusty)
https://linustechtips.com/topic/851843-glass-panel-proscons/#findComment-10620130
Good advice, thanks.
Love not hate
https://linustechtips.com/topic/851843-glass-panel-proscons/#findComment-10621879
