I just got a new sshd that I was going to use for my laptop since it's factory one died, I was going to download windows 7 onto a drive but i couln't , I needed a key. I put the preinstalled windows key from that laptop in and it didin't work because of that. How do i get my laptop to work? Please help asap!
https://linustechtips.com/topic/850603-i-need-help-right-now/
1 minute ago, TinyBolts said:
I just got a new sshd that I was going to use for my laptops since it's factory one died, I was going to download windows 7 onto a drive but i couln't , I needed a key. I put the preinstalled windows key from that laptop in and it didin't work because of that. How do i get my laptop to work? Please help asap!
upgrade to Win 10 for free or send in the dead drive for factory recovery of data.
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601514
Just now, l4v4v3x said:
Ok, calm down... now, that is an OEM Key you are trying to use, thus you will need a OEM install media. but, i would just enter the key, try to activate and when it gives the cannot activate error. use the automated phone system to activate. should work.
alright, I'll try.
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601525
windows 10 upgrade stopped a while ago
its 20 euro :/, I could just download windows off softonic or smth but I don't trust them.
https://www.keysdeal.com/windows-10-pro-professional-key.html?acc=1
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601526
There is no call thingy. Laptop is from dell also.
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601555
Sometimes calling Microsoft is the way to go. It can be a huge pain but use it while you still have the support.
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601558
7 minutes ago, Haeking said:
Download windows 10, get a key for windows 10 off kinguin for like 5$
I refuse to use Kinguin anymore. When they charged against my canceled credit card for no reason I stopped trusting them.
ORLY?
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601567
Just now, TinyBolts said:
As he said, it must be oem, no way they will help.
PM me.
ORLY?
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601571
here, DM me if you would like my old Windows 8 key i don't need then use https://www.microsoft.com/en-us/software-download/windows8 to download windows 8 to a usb key. install windows and activate using the key I will DM to you. after that, go to https://www.microsoft.com/en-us/accessibility/windows10upgrade to download the upgrade assistant and go from there.
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601578
This is a bit of a legal grey area... I wouldn't use Kinguin.
19 minutes ago, TinyBolts said:
the os in the dead drive was windows 10.
If it was Windows 10, just reinstall Windows 10 and skip the licence key part of the installation process. Windows will automatically recognise your hardware and activate for you.
I edit my posts a lot.
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601626
how do I reinstall windows 10 on a dead drive. Also, I cant download windows 10 cuz I need key.
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601827
You need to use another computer to make some installation media. So you need an 8GB+ USB flash drive and use this tool: https://www.microsoft.com/en-gb/software-download/windows10
Then plug it into your dead computer and reboot - installing as usual.
You don't need a key because Windows 10 will have automatically logged your computer hardware (MAC Address etc).
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601855
my usb is 3gb :(
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10601859
Kewl
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10602134
2 hours ago, TinyBolts said:
Kewl
I don't know if they still do it, but in the past DELL has included the keys for the OS on a sticker underneath the keyboard.  If you can find a guide for disassembling your laptop online, you probably have a good chance of seeing if it's there.  Usually getting the case off is one of the easier disassembly steps, but if you 'f it up, you can break something.
EDIT:  Sorry, I saw that you had tried a key, but didn't realize it was the factor one.  My bad.
https://linustechtips.com/topic/850603-i-need-help-right-now/#findComment-10602574
