You need nothing more than the stock fan if you're not overclocking. Performance boost of an OC depends on how much you overclock.
You can keep the stock fan but be prepared for heat and noise. If your not limited by budget get 120mm air cooler.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
slightly exaggerated, the amd stock cooler aren't particularly loud. usually by using better thermal paste, like some artic silver will make a greater difference to temps than a cheap 120 mm air cooler.
