PC Booting Problems
Go to solution Solved by SMass620,
I fixed the problem by doing cmos with 2 pins and a metal object. I still cant get my pc to recognize my graphics card though
Hey, I just installed my gpu, and started the system. My monitor connected to the existing onboard graphics lit up, booted perfectly. Then I shut down to disable the integrated graphics. It had an option titled Disable Intel Graphics and it was enabled, so I disabled and I saved. The pc rebooted and nothing came up anywhere. So I rebooted it again. What do I do?
Edit:
CMOS SAVE ME. Can someone find out where cmos is on my mother board (gigabyte ga-b85m-hd3 r4)
https://linustechtips.com/topic/849928-pc-booting-problems/
make sure to set ur dedicated gpu as ur PCI-E gpu not iGPU when u turn off the igpu ;v
maybe ur using a wrong port on ur gpu tbh :P could be that u put the monitor in output slot 2 of the gpu, while slot 1 actually gives the screen ._.
https://linustechtips.com/topic/849928-pc-booting-problems/#findComment-10594093
You have to plug the monitor into the GPU.
https://linustechtips.com/topic/849928-pc-booting-problems/#findComment-10594097
Make sure to tag and/or quote people so they get notified... :P:D
My gear:
                                                         Ryzen 7 2700X / Gigabyte GA-X370M-Gaming 3 / R9 380 Nitro 4GB/ 16GB DDR4 2133 / 225GB OCZ Trion 100 / 3TB of hard drive storage
        AOC C24G1 / BenQ GW2270H(rarely overclocked to 87Hz :P )
        Razer Blackwidow / Redragon Kumara / Logitech G Pro Wiress / Sennheiser HD 559
        Microsoft LifeCam Studio / Tonor BM700 microphone
Panasonic Lumix DC-FZ82 / Canon EOS 80D
#PCMasterrace
https://linustechtips.com/topic/849928-pc-booting-problems/#findComment-10594100
Your CMOS is the little round battery under the socket. Remove it for a minute or so, put it back in, boot.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/849928-pc-booting-problems/#findComment-10594103
15 hours ago, SMass620 said:
Which one do you mean, can u send me a diagram
There should only be one. Circle. To the right, directly underneath your cpu socket.
6 hours ago, SMass620 said:
Do I need to buy another battery for cmos or do I put it out for a sec, then put it in?
No, you shouldn't. Just take it out for a min and put it back in. However it may also just be worth trying with a new one, in which case you need to buy a CR2032 lithium coin cell, which you can buy at your local supermarket or office supply store for a few dollars.
My PC:
https://linustechtips.com/topic/849928-pc-booting-problems/#findComment-10598153
