Psu for Coffelake build.
Go to solution Solved by STRMfrmXMN,
7 minutes ago, Vacras said:
Hey guys,
I’m currently working on a CAD (with some gaming as well) build for a friend of mine. I was looking at the EVGA Super Nova G3 550w.
I plan on using the i7 8700 for the build (hopefully it will be in stock around Christmas duh).
Any other suggestions? Here in Germany the G3 is 80€ and it would be somewhat nice to push a little more budget towards the GPU but I also don’t like cheaping out on the Psu.
The 550G3 is fine.
Hey guys,
https://linustechtips.com/topic/849469-psu-for-coffelake-build/
Hey guys,
The 550G3 is fine.
https://linustechtips.com/topic/849469-psu-for-coffelake-build/#findComment-10589307
4 minutes ago, Vacras said:
The g2 is 15€ more. Isn’t the g3 the successor of the G2?
the CXM would be 65€ so I’m looking into that thanks.
the others are more expensive
If you're doing CAD for a living then I would get the best PSU you can afford. The G3 is up there.
https://linustechtips.com/topic/849469-psu-for-coffelake-build/#findComment-10589343
Well it’s not for a living, but I’m with you. Get a good Psu and use it for the next 5+ years instead of cheaping out :)
5 minutes ago, L.Lawliet said:
Yes but u know..typical annoying salesman..
The CXM is inferior to G3 but its gonna be fine..
Ah gotcha :P
Thank you guys!
https://linustechtips.com/topic/849469-psu-for-coffelake-build/#findComment-10589356
It should be noted that the EVGA SuperNOVA G3 has an aggressive fan curve that ramps up the fan at low loads, and therefore is loud.
For 80 euros, I would recommend the BitFenix Whisper M.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/849469-psu-for-coffelake-build/#findComment-10590484
Noise isn’t as much of an problem for this build :)
https://linustechtips.com/topic/849469-psu-for-coffelake-build/#findComment-10590495
