Around 10 degrees difference between core and package temps on custom loop
Solved by W-L,
5 minutes ago, xHadrian said:Hey, so about a month ago I finished my first hard-line loop. However, I've noticed that there is around a 10~ degree difference between my package and core temps. I didn't really think much about it, since it was a new loop, but now 1 and a half months later it's starting to bother me. Any help would be appreciated.
Specs:
i7 5820k @stock
GTX 980 Ti @stock
240 rad
360 rad
Thermaltake Riing Fans
H440
The core temps are what you want to be mainly concerned about the package is usually the CPU as a whole or socket for ones with temp probes usually seen on the old AMD chips.
