7 minutes ago, Kingjames0202 said:
So i recently got new monitor that can go up to 144hz but when i connect my duel link dvi cable and switch the source to that it just shows a black screen. Does anyone know why this is.
Try Display Port, DVI can't handle up to 144hz.
https://linustechtips.com/topic/849076-144hz-issues/#findComment-10585205
DVI supports 144 Hz just fine, for some 144 Hz monitors that is the only connection they have that supports it.
https://linustechtips.com/topic/849076-144hz-issues/#findComment-10585213
