I am putting this in this section because I am 99% sure it is Mobo related.
Most times when I do a cold boot on my system it will go strait into the Bios.  No errors, no problems.  I just never get a windows boot screen.  I have to restart the system multiple times to finally get into windows.  Sometimes going as far as to turn the PSU completely off.
This never happens on a simple restart.
Relevant parts are as follows.
Rampage V Edition 10
6850K
Samsung 960 Evo NVME boot drive.
Asus Thunderbolt 3 card.
 System is overclocked and stable but I have tried resetting to factory defaults and the issue still persists.
Tell my tale to those who ask. Tell it truly; the ill deeds along with the good, and let me be judged accordingly.
https://linustechtips.com/topic/848697-really-strange-startup-issue/
Have you tried to switch to SATA disks?
Have you tried a different PSU?
Also, please post full specs.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Have not tried to boot from a SATA disk.
Tried a different PSU
6850K
64Gb G.Skill TridentZ 3200 Quad channel memory running at 2600.
4 x 500Gb 850 Evos in Raid.
2 x 1TB 850 Evos in Raid.
EVGA 1080TI FTW3
EVGA G2 1000P Power Supply.
Currently running Air cooling on the GPU and a Kraken X62 on the CPU until I get this figured out and feel comfortable hooking my Loop back up to it.
Generally the mobo will default to the UEFI if it cannot find a "suitable" boot drive.
Check and make sure your UEFI is up to date.
If you were or were not using secure boot make sure that didn't get changed.
If you have a usb stick with windows on it, boot to that and run the repair to make sure your boot loader isn't corrupt.
i7 10700k @ 5.1Ghz, 1.37v | Asus Z490-E Strix | Asus Rtx 2080ti Strix | 16Gb Trident Z Rgb @ 3600MHz | Samsung 970 Pro | EVGA Supernova G2 850w  | Corsair 500D | Celcius s36 /w ML Pro's
i7 8700k @ 4.8GHz, 1.31v | Asus Z370-A Prime | Asus Gtx 1080ti Strix | 16Gb Corsair Dominator Platinum | Samsung 850 Evo | Corsair TX 650W  | Corsair 750D | Corsair H100i v2 /w SP-120's
