Yeah that's good. Not seeing anything wrong here at all.
1 minute ago, onlybuilt4cubanxlinx said:
Awesome parts. I'd get a new less noisy CPU cooler though. For all the awesome shit you have in your computer you should upgrade the cooler part for sure.
If you believe so then i shall thx for the help :D
Maybe invest in a liquid cooler
idk man how does that work i dont know much of pc parts and stuff i had a friend help me with this pc that im using right now and he also built it so i know nothing about liquid cooling
1 minute ago, Brooksie359 said:
psu is garbage. the gpu is not a good value I would get a better 1080 for that price. other than that it seems like a solid build. the case is a bit more expensive than I would spend on a nice one but that is more preference.
well what PSU do you recommend
https://pcpartpicker.com/list/bcspXH not a evga nex psu. get a g3 or g2. I also changed the gpu model to a good aftermarket one that is cheaper than the one you choose and will preform better.
https://pcpartpicker.com/product/YjPfrH/cooler-master-power-supply-rs750amaag1s1
what do you think of that one
Why is no one recommending the 8700k over the 7700k? 200 series boards will receive no further upgrades and are not compatible with coffee lake parts. It's much smarter to hold onto your money for a little longer and wait for stock to come back in.
My main desktop, "Rufus":
PC Specs:
CPU: AMD Ryzen 5 1600
CPU Cooler: Cooler Master MasterLiquid Lite 120
RAM: 2x8gb Corsair Vengence DDR4 Red LED @ 3066mt/s
Motherboard: MSI B350 Gaming Pro Carbon
GPU: XFX RX 580 GTR XXX White
Storage: Mushkin ECO3 256GB SATA3 SSD + Some hitachi thing
PSU: Seasonic Focus Plus Gold 650W
Case: Corsair Crystal 460X
OS: Windows 10 x64 Pro Version 1607
Retro machine:
PC Specs:
CPU: Intel Core 2 Quad Q9550
CPU Cooler: Stock heatsink
RAM: GSkill 4gb DDR2 1066mt/s
Motherboard: Asus P5n-e SLI
GPU: 8800 GTS 640mb, I swap between that and my 8800 GTS 512mb
Storage: Seagate 320gb right from 2006
PSU: Ultra 600W
Case: Deepcool Tesseract SW
OS: Windows XP SP3 32-bit, Linux Mint 18.2 Cinnamon 64-bit, Manjaro Deepin x64 (sorta)
Mac Pro Early 2008: Dual Xeon X5482s w/ 32GB RAM & HD 5770 running macOS High Sierra
More PC's
Just now, tony249245 said:
so i would need a new mother board to put that CPU right
Yes, just hold on to your money and get a z370 + 8700k instead of the z270 + 7700k. 8700k usually either matches or outpaces the 7700k in games once overclocked.
PC Specs:
Retro machine:
PC Specs:
PSU: Ultra 600W
More PC's
what about rendering vids and stuff way better or just 20% better
See for yourself.
PC Specs:
Retro machine:
PC Specs:
PSU: Ultra 600W
More PC's
43 minutes ago, tony249245 said:
So I'm about to build a new pc but I need to know if these parts are good or not and what to change for better performance and things like that :P
https://pcpartpicker.com/list/bHDjm8
A lot of your specs are the same as mine, with minor differences.  If you're trying to stay at or under 3k, I'd cut back on either the keyboard or monitor and get a M.2 960 EVO instead.  You can check my specs.  I boot near instantly and run everything smooth af.
A lot more bang for the buck if you get a Dell monitor.  I got  a 2560x1440 @ 144hz for $500 on amazon.  Save ya $200 right there.
https://pcpartpicker.com/product/R7V48d/seasonic-power-supply-ssr650rm
I7 8700K has 2 more cores 4 more threads and higher turbo frequency also Cache 12 MB
An M.2 is a socket on your Motherboard that connects directly to the CPU it is used for even faster storage via PCI-Express that's either Mvme 4x 3.0  or Sata bus
nah my peripherals are there for a reason I'm not planning to change any of that I also saw that SSD and a lot of reviews on it and it is great but id rather get the other one just because it's more compatible with things
I understand.  Just bear in mind I was able to buy 32GB (16x2) RAM at 3200 hz, a 1080Ti Superclocked and the 960 Evo for only a few hundred more than you are spending.
