Help Required Ryzen 7 1700 using 1.4v on stock no OC
Solved by Vishant,
11 hours ago, dave_k said:Yeah, the voltage is fine.
The ISL95712 is not the best part, so the voltage cartwheels are possible.
Thanks for the response mate. Since I am not looking to overclock this chip at all. I think this motherboard should hold up for few years that I am planning to do. I'll do check your guide before making the purchase so that I can get the best.
Currently, I'll be focusing on upgrading my GPU to a 1070 or better.聽
Thanks Guys for assistance. I'll mark this as resolved.聽
