Cable management.
Solved by Guest,
Yeah. "Cable management" is about the labor, not so much the product. The cables don't manage themselves. YOU have to be skilled enough to route, hide and tie down the cables properly. The case isn't going to do it for you.
Some cases are better at giving you holes to feed cables through and places to zip them down than others. And a modular PSU makes it easier because you can route the cable, hide it, etc. before you even install the PSU.
Is this going anywhere? Because you seem to be talking us in circles. Is this just a matter of you've never built a PC before and you're worried about how neat it's going to look inside because you don't know what parts you should buy?
