So I have a "Frankenstein" pc that has been giving me problems ever since I fresh installed windows on an ssd. The system uses a Lenovo m91p mobo, i5 2500s cpu, 5 gigs of ram (all have the same clock speed, all of it is kingston memory), gtx 580, Sandisk 64gb ssd (an older one), a pcie to USB 3 card and two ancient seagate barracuda 120gb hard drives running striped together. The problem I have been having is with the sleep/wake function not working (once my keyboard backlight goes out I can not wake up the system) and more often than not when I shut down the PC the fans are all still running after the OS shuts down and I have to manually power it down. I have checked for literally every diver possible from both intel and lenovo and I can not seem to remedy the problem. This problem has only existed after I moved from a mechanical HDD OS disk to a SSD OS disk.
https://linustechtips.com/topic/846709-random-system-instability/
I had an issue like that, spent a month and a half trying to figure out the issue, well 2 weeks trying to figure out the issue (OS was corrupted) and a month futilely trying to fix it. Ended up doing a clean install and it didn't come back
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Yeah, I have probably reinstalled the os (from a fresh install iso each time) about 4 times, nothing has worked. I have also tried the refresh option as well and that did nothing. This problem only showed up when I installed the ssd which originally had the system image from the HDD on it. In the "disk manager" it shows up as a basic hard disk, not a solid state disk. Is this a problem? I made sure I am running a AHCI and my bios is the most current revision.
Update: just reinstalled windows 10 from scratch and still have the "no wake" and "no shutdown" problem. I think my system is trying to wait for the SSD to spin down and that may be causing the problem. Is there any way to tell the system that the C drive is an SSD or is that more of a bios problem?
