Hey LTT forum bros, just thought I'd run this past you guys before I bought it because it's always a good idea to get a second opinion
Thinking about snagging this deal on newegg.com because I want to Overclock my new 3570k, and contribute more to the folding at home team.
Things i like out of cpu coolers
-Quiet
-Efficent
-able to run good overclocks without sounding like a freaking hair drier.
Saw this deal today http://www.newegg.com/Product/Product.aspx?Item=N82E16835214023
- It's only got a  21dba rating
- would most likely fit in my cooler master N200 case
-Teksyndicate did a review on it and it had adequate performance
Questions:
Should I get it, and be able to achieve a moderate overclock (depending on my lottery ticket)?
Would it most likely fit in my cooler master N200 which has 6.3 inches of clearance between the side panel and I don't have a side case fan installed?
Any other suggestions on cpu coolers is welcome. trying to stay under 50 dollars for one. Which limits mean mostly to air cooling.
Thanks!
https://linustechtips.com/topic/84611-cpu-cooler-for-3570k/
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/84611-cpu-cooler-for-3570k/#findComment-1151190
212 evo
current system:  i5 2500k @4.5ghz cooled by antec 620 - asrock z77 extreme 4 - 8gb corsair RAM - MSI Twin Frorz 7950 in crossfire - XFX 850w  - Fractal design R4 - samsung 840 120gb ssd - 500gb wd blue hdd - 1440p korean qnix monitor (love it!)
https://linustechtips.com/topic/84611-cpu-cooler-for-3570k/#findComment-1151214
For air coolers I'd go with a noctua NH D14 or NH U14 and for liquid throw an h80i/h100i on there. As for the one you linked, never heard about it.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/84611-cpu-cooler-for-3570k/#findComment-1151217
https://linustechtips.com/topic/84611-cpu-cooler-for-3570k/#findComment-1155743
