USB 3.1 Gen2 hub?
Solved by mariushm,
Yeah, you could buy extension cables :
1m (3.3ft) extension cables : https://www.amazon.com/CableCreation-10Gbps-Extension-Nintendo-Macbook/dp/B01FM4ZWV0/
OR https://www.amazon.com/Extension-Cellularize-10Gbps-Nintendo-Macbook/dp/B072FMVF2C/
or smaller 2 ft one : https://www.amazon.com/Extension-Devices-Through-Connector-Extender/dp/B06WD5VXTB/
You can probably find extension cables with Type A connector as well, or adapters that change type a to type c (and then you can use that extension cable), but i can't be bothered to search for them.
