Battery Question
Solved by samcool55,
Just now, babadoctor said:So... how much battery does my battery have then...?
I plugged it in and with power still in it it took 7 hours to charge
Well, unless you have a proper system to check their charge constantly, something else to put a constant load on it and something that cuts power once a specific voltage is reached, you can't.
How long it took to charge also depends what charger you have and other things.
I would get lipo's from a decent brand. You can find batteries with the same size and similar capacities for little money so that's what i would do.
