Help with my Math?
Go to solution Solved by Levisallanon,
Question:
Quote
A tire on a car turns 300 times per minute when the car is travelling at 55 km/hr.  What is the diameter of the car tire?
Answer to the nearest cm
Key Formula:
circumverance of circle = pi * diameter
Solution:
1 hour contains 60 minutes.
so in 1 hour the tire turns 300 * 60 = 18000 times.
the distrance traveled in this hour is 55km = 55000 m
so the distrance traveled in 1 turn of the tire is: 55000 / 18000 = 3 1/18 (notated in fractals so there isn't any rounding done here)
so we now know the circumverance of the tire is 3 1/18 m inputting this in the equation we have:
3 1/18 = pi * diameter
so
diameter = (3 1/18) / pi
so
diameter =  0.97261.... m
the answer needed to be given in centimeters and rounded to the nearest centimeter so this will be:
diameter = 97 cm
All my math is basically online, there is a dumb question that I legit just don't understand. To make matters worse I got a terrible teacher that sometimes shows up and you can maybe ask him a question during class time.
Pre Cal 10.
That is all the info we get. Any help?
https://linustechtips.com/topic/845551-help-with-my-math/
Pre Cal 10.
I feel you. My precalc teacher was terrible too, never really teaching, and I understood that bc he had a degree in computer science instead. He was bad enough to the point where I can't remember learning this in his class. But I feel like there is some formula dating back to geometry you had to use or something.
https://linustechtips.com/topic/845551-help-with-my-math/#findComment-10546939
55 divided by 60 gives you km per minute.
Then you need to find how many cm are in one revolution.
Then you need to divide the cm by pi.
I might be forgetting a step, but hopefully this helps somewhat.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/845551-help-with-my-math/#findComment-10546940
Question:
Quote
Key Formula:
Solution:
so
so
diameter = 97 cm
https://linustechtips.com/topic/845551-help-with-my-math/#findComment-10547697
2 hours ago, Levisallanon said:
So the distrance traveled in 1 turn of the tire is: 55000 / 18000 = 3 1/18 (notated in fractals so there isn't any rounding done here).
This is a fractal.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/845551-help-with-my-math/#findComment-10547979
