Hi everyone, i need some help to pick right PSU.
CPU:i7 7700k 4.2Ghz
GPU: MSI Radeon RX 580 armor 8gb oc
Motherboard: Asus Prime z270 plus
RAM: CORSAIR Vengeance 2x8GB DDR4 2400MHz VG LPX
Cooler: Cooler Master Hyper 212x
Case: Corsair Carbide Alpha
SSD: 240GB Sandisk plus
Thanks in advance for your help.
https://linustechtips.com/topic/845536-i-need-help-pick-right-psu/
something in the 500 to 650W range and you'll be fine. reputable brand of course corsair evga seasonic
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
Corsair CX550M (or you could even go with 450M if your GPU has only one 8-pin and no 6-pin) is a really good value.
I have a PSU tier list in my sig -- anything tier 3 or better is good.
you only really need 450W, but 550W is more comfortable, and if you are considering SLI/CF, then maybe get a 650W
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Yeah, a 500-650W would definitely be fine, even for overclocking. Even if you pick a reputable brand, I would recommend getting at least a mid-range model. The cheaper models won't burn your house down, but the step up in quality from a $40 PSU and a $70 PSU can be pretty big.
i7-6700 @ 4.4GHz || Asrock Z170 Pro4 || MSI RX 480 Gaming X 8GB || Sandisk 480GB SSD + 2x Crucial 128GB SSD + Seagate 3TB HDD
2x8GB G.Skill 2133MHz || NZXT S340 || Cooler Master Hyper 212 Evo || EVGA B2 750W || AOC G2260VWQ6 Freesync
CPU:i7 7700k 4.2Ghz
1. Why do you want a glorified 4 Core CPU right now when there are 8 core CPUs available for the same price?!
And don't come with 'its better for gaming', yeah, that was said about the Single Core CPUs at the time or Dual Cores like the E8600 vs. Q9550. And as we know, the "more core" CPU was the better and longer lasting one.
2. A good quality 400W/450W PSU is more than enough for that build.
I have an i7-3930K and a Power Color RX480 Red Devil and barely am able to get past 350W.
Why do you think he needs 500W??
"Hell is full of good meanings, but Heaven is full of good works"
because people always go overkill and with OC the i7 runs around 130W with a GPU that has 200W OC to use, let's say 250W add in around 20~30W more for fans and drives you're getting awfully close to your 450W max output. so 500W is my recommendation and it's a sensible one. 650W is clearly overkill to be perfectly in the efficiency curve, some people really care about hitting that
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
