Various HDD and SSD linked with the same SATA cable: performance hit?
Over
I would like to know if I plug 2 SSD and 2 HDD to the same SATA cable, will I get lower performance (as max out the SATA bandwitdh capacity)?
SATA is point-to-point, can't be done AFAIK.
But maybe you're talking about an SF-8087 cable branching out to four ports? Then no,
the circuitry is designed to handle four devices attached to an SFF-8087 cable, so
there won't be a performance hit. SFF-8087 is actually a SAS connector though (you
can still hook up SATA drives to it).
See here for more info on SAS connectors.
EDIT:
That's a power cable, not a data cable. Has no influence on performance.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
it's for power so no problem I'd say
@alpenwasser, seems like he is talking about sata-power
I think he was confusing the linked cable as being a data cable rather than a power cable, which is what it really is.  :P
"will I get lower performance (as max out the SATA bandwitdh capacity)?"
Yeah, I was too slow with typing. ;)
According to TweakTown, there is no observable performance loss.
Remember that what you linked is a SATA power cable, not a data cable.
I can't believe somebody was actually thorough enough to test this. :lol:
But it's good to have some facts, I'm always in favour of that. :)
Just as an fyi, it is possible to plug as many as 5 drives into a single SATA connection, but it requires some pretty expensive hardware to get working and it's far from optimal - it's not meant for consumer applications. It basically involves having some kind of active (powered) controller on a PCB to control it iirc.
No, I was really being silly.
So I need two cables to connect my new SSD. The power cable with the 4 plugs (the one I have has only three plugs) and a new SATA data cable. Although I think I should have checked out if I have a free SATA slot in my MB before buying the SSd in an Amazon's lightning deal (couldn't pass up a Crucial 240GB SSD for 90€).
