ST45SF Not enough or Defective ?
First of all thank you for using your valuable time to read this post.
So i bought a new sff psu to pursue my dream of building my own mini itx system and its the silverstone st45sf 450W non modular PSU (not exactly the sf450 but i am pretty sure they are very similar if you dont need a modular psu)
my setup is listed below;
CPU: 6700k (game mode on the mobo on so it runs at 4.4 Ghz with reasonable temps.)
MOBO: MSI Z170I Gaming AC
RAM : 2x8 GB Corsair Vengeance 2400 MHz
GPU : Evga Geforce 1060 SC (small one)
Storage : 480GB Sandisk ultra 2 SSD and a 1TB Seagate barracuda 7200 Rpm HDD
Cooler : Cooler Master Evo 212
i build the system like 2 days ago and just started playing some Rocket league today , 2 days ago it was on a motherboard box with the st45sf psu and i played almost everything .. made a stress test and all ..
today my system is in a bitfenix prodigy (i will swap to node 202 in the near future) but even while playing rocker league which is not that damanding my pc just shuts itself down and turns back up for no reason.. (at random times..)
sometimes it just takes a minute , sometimes after 2-3 hours..
so now im worried , i swapped the psu for an 8 year old 620W Cooler master ATX unit and i am doing aida64 + furmark at the same time while writing this post (its been 29 minutes so far but it will be stress tested at least 8 hours while i sleep)
after i realized the random resets i tried to do the same with aida64 and furmark and psu started resetting in a matter of minutes (i tried it like 6-7 times and everytime this happened)
So what do you guys think ? is the sff450 unit not enough ? or does it have some kind of defect ?
i see people running 7700k s and 1070s with sf450 psu s so im leaning more towards the defect probability..
again thanks for reading this hidious post and your possible help !
Seems like the 450w is getting too hot from constant load. Its only rated at 450w up to 50 celcius. Having it running constantly with a stress test going is going to heat it up more then that. BUT i'm more likely to say its just not enough. Remember when you OC anything power usage increases significantly
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
