So i have a Gigabyte X58 mobo with the latest BIOS. The board can get into windows, everything works etc. BUT, before that any USB device will not work, trying to boot from USB won't work, any USB keyboard doesnt' work, but a PS/2 keyboard does. What's more odd is that even using the PS/2 keyboard i can't get into BIOS, i press DEL, the screen freezes and the PC restarts, if i don't press anything it'll go into windows normally. The South Bridge gets pretty hot.
I tried a new CMOS battery, reseting CMOS, a different CPU. Idk what else to check. Thanks in advance
https://linustechtips.com/topic/844907-odd-mobo-problem/
enable legacy usb support and problem should be solved, by default its set to auto/disabled
use the ps/2 keyboard to enable legacy support
https://linustechtips.com/topic/844907-odd-mobo-problem/#findComment-10540143
Quote
Kinda an issue when this happens all the time
https://linustechtips.com/topic/844907-odd-mobo-problem/#findComment-10540169
that can also be caused by wrong cas latencies set on ur ram :P
make sure that is set proper aswell :P  if u cant get in the bios at all just rma the board / swap it for another
https://linustechtips.com/topic/844907-odd-mobo-problem/#findComment-10540172
Tried different ram sticks, no luck.
Can't RMA the board, it's from 2010, 1366 LGA...can't exactly swap to another, it's not worth since these sell for too much (100€ or so)
https://linustechtips.com/topic/844907-odd-mobo-problem/#findComment-10540189
oh yah forgot x58 is 1366 haha xD
tbh if the southbridge been running hot for a long time it might just start with defects now ;v i know it sucks but certainly possible especially if u been ocing alot :v
if the ramstick swap also doesnt work i dont know really i think its within the chipset of the board maybe
what also is a possibility i had this same issue when i had a device connected in any usb port connected to the mobo that my mobo couldnt boot up ( maximus vi hero ) for example if id have my phone connected it would freeze as soon i try to boot the bios ect haha
https://linustechtips.com/topic/844907-odd-mobo-problem/#findComment-10540196
this mobo just went from semi-ok to the fok is going on??
So now it goes to the post screen and then shuts down, never going past it...i hate technology sometimes -.-
https://linustechtips.com/topic/844907-odd-mobo-problem/#findComment-10540469
