I recently discovered that my new Aspire 5 with the MX150's CPU Power Limit Throttles when the GPU is pegged at 100% usage.
image.thumb.png.a7a7507886a49991fbd8f628b4dabc16.pngAt normal usage.
image.thumb.png.c081d3d389be657efbe01f7368ba2450.pngAt full usage.
This causes terrible frame drops, which get really annoying.
Can anyone help me?
Edit: I just called Acer Tech Support and the guy was very unhelpful and suggested me to reinstall windows.
https://linustechtips.com/topic/843674-cpu-power-limit-throttling/
Can anyone help me?
I believe that'd be because they're sharing a heat pipe.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
Just now, SkylakeAlex6700k said:
So it does that to avoid overheating?
No, it's just a thing laptop manufacturers do to reduce costs I believe. Shared heat pipe means that both CPU and GPU are under one heatpipe when they should each have one.
Main PC:
Case: TT P3
HTPC:
that=throttle.
So it throttles in order to not overheat?
1 minute ago, SkylakeAlex6700k said:
that=throttle.
Indeed.
Main PC:
Case: TT P3
HTPC:
Sad Face. Am going to Re-Past it with some IC Diamond.
They might not be sharing a heat pipe however, I have not seen the inside of the laptop. Re-paste and see if it helps, if not try to increase fan speeds.
Main PC:
Case: TT P3
HTPC:
Will do, It does have a single shared heatpipe.
As expected. Re-paste and increase fan speeds. It should help.
Main PC:
Case: TT P3
HTPC:
Thank you, you are 1000% better than tech support!
No problem, hope it works out!
Main PC:
Case: TT P3
HTPC:
